aesnakes Posted January 28, 2012 Share Posted January 28, 2012 Hello everyone, Im wonder if anyone has some successful methods of getting renders from Mantra and combining the passes back to beauty. We work with Vray and I have used renderman but for some reason I can not get renders from Mantra to combine back to match the beauty pass. let me know any techniques you use or passes necessary in any situation like volumes, SSS, normal basic scenes...Id really appreciate any light you can shine on this topic. Thanks Rob B Quote Link to comment Share on other sites More sharing options...
xtimmyx Posted January 28, 2012 Share Posted January 28, 2012 Well it all depends on how your shader is built. If you multiply ambient occlusion with diffuse in shader for example, you need to do that in your comp as well. However if you use the default Mantra surface material and the standard diffuse/specular/reflection/refract/emission outputs from the drop down menu in your Mantra ROP it should just be a matter of adding (plus) them together to recreate the beauty. Haven't tried with SSS though. Quote Link to comment Share on other sites More sharing options...
hopbin9 Posted January 28, 2012 Share Posted January 28, 2012 The default passes that the Mantra Surface shader uses will not reproduce the beauty pass. I've never had success trying to reproduce it without having to create my own exported parameters in the shaders to get the right passes. Mainly the diffuse, lighting and reflection passes need to be done yourself. Quote Link to comment Share on other sites More sharing options...
robert.magee Posted March 13, 2012 Share Posted March 13, 2012 The default passes that the Mantra Surface shader uses will not reproduce the beauty pass. I've never had success trying to reproduce it without having to create my own exported parameters in the shaders to get the right passes. Mainly the diffuse, lighting and reflection passes need to be done yourself. Here is a file that shows a simple example of getting render passes out of Mantra Surface - this includes a control for shadows. Be sure to check out the render output nodes and the compositing networks to see how this all works: http://www.sidefx.com/images/stories/transfer/render_layers_sample.zip Quote Link to comment Share on other sites More sharing options...
gaurav Posted March 14, 2012 Share Posted March 14, 2012 Here is a file that shows a simple example of getting render passes out of Mantra Surface - this includes a control for shadows. Be sure to check out the render output nodes and the compositing networks to see how this all works: http://www.sidefx.com/images/stories/transfer/render_layers_sample.zip Hi Rob, Thanks for the hip file. Nice setup. However, I noticed few small things with the compositing setup. 1. There is a dark edge where sphere and box intersect each other. 2. Composite alpha is not added up. IMHO correct order should be something like following : Since box and sphere are held out by each other we need to plus both of them instead of layering over function which is fg*matte + bg*(1-matte) afaik. Also in the last layer op we need to change the alpha operation to "add" instead of the default over "same as above". Thanks, Quote Link to comment Share on other sites More sharing options...
