Vex shader
exarhos2003
ran into a stump, in my vex shader It calculates the angle between two vectors for diffuse value. then its divided by the angle to give a value of one. this is just a test use.
So, it displays in the SHOP viewer, but not on the geometry.
Im converting my value(float) to a vector, first input only for red color,then into lighting diffuse, then output(Cf).
any thoughts,
christopher
At the moment I am biting off more than I can chew with VOPs and getting into the area of the dot product. and things I have found is it returns the a number that if you want the angle you need to put it through the 2 normalised vectors then put it trough the acos to get the angle in radians.
acos( dotp(V1,V2))
convert it to degrees if that is what you need to work with.
Now I am new to this so I may not be rite but it may help.
