sparkChan Posted February 6, 2012 Share Posted February 6, 2012 Hello, all friends, I need help to know how to render "specular" in Houdini, I know how to render in Maya but as a new comer of Houdini, I'm confused, so SOS to international friends!!! Thank you all very much!!! Quote Link to comment Share on other sites More sharing options...
~nature~ Posted February 6, 2012 Share Posted February 6, 2012 You could specify the extra image plane (there's specular option there) in mantra rop assuming you use mantra surface shader. Quote Link to comment Share on other sites More sharing options...
sparkChan Posted February 8, 2012 Author Share Posted February 8, 2012 You could specify the extra image plane (there's specular option there) in mantra rop assuming you use mantra surface shader. Thank you for your reply, but I want to know how to render "specular pass" not assign a "specular Map" !!! Thanks again! 2 Quote Link to comment Share on other sites More sharing options...
csp Posted February 8, 2012 Share Posted February 8, 2012 Thank you for your reply, but I want to know how to render "specular pass" not assign a "specular Map" !!! Thanks again! In Houdini pass are named image planes! Peter Quint has a basic tutorial on that http://vimeo.com/13042237 Quote Link to comment Share on other sites More sharing options...
~nature~ Posted February 10, 2012 Share Posted February 10, 2012 (edited) Yep, You could access many other render passes in mantra rop. Edited February 10, 2012 by ~nature~ Quote Link to comment Share on other sites More sharing options...
