Wolf-S Posted February 16, 2012 Share Posted February 16, 2012 (edited) Hello all, Houdini seems to be eating up 1 MB of memory per execution of this Python operator: import inlinecpp iterations = inlinecpp.createLibrary(name="cpp_heat_iteration_library", includes = """ #include <GU/GU_Detail.h> """, function_sources=[""" void iterate(GU_Detail *geo){ return; // stuff } """]) geo = hou.pwd().geometry() iterations.iterate(geo) There's a bunch of stuff after 'return;', but I've narrowed it down to this and it's still eating 1 MB of memory per execution. Is there something I'm doing wrong? I have a particle system, amongst others, connected to this node which makes all the difference. Once it's off, it doesn't eat up memory. It makes no sense... Edit: To add to this, said POP network only creates 1024 particles from a grid - nothing too complicated. Edited February 16, 2012 by Wolf-S Quote Link to comment Share on other sites More sharing options...
petz Posted February 18, 2012 Share Posted February 18, 2012 its a known problem. in your last line where you call the function, replace geo with hou.pwd().geometry(). don´t ask for the geometry outside the inlinecpp-function. see attached file! petz memory-test.hipnc Quote Link to comment Share on other sites More sharing options...
Wolf-S Posted February 28, 2012 Author Share Posted February 28, 2012 its a known problem. in your last line where you call the function, replace geo with hou.pwd().geometry(). don´t ask for the geometry outside the inlinecpp-function. see attached file! petz Thank you, that works. P.S. I've since switched to compiling non-inlinecpp with hcustom and haven't had problems yet. Quote Link to comment Share on other sites More sharing options...
