Composite COP & Alpha
gradualepiphany
I've found an odd bug using the over function inside of the Composite cop - I've got Image A over Image B - A has an alpha channel, B's alpha is completely white. Even if I HSV or Bright A's alpha down to complete black, A will still be about 60% visable.
Any ideas?
thanks,
|andrew|
Yup i'm getting it too (175,linux), you should post this at SESI, they'll want to know about it.
Same with the Layer cop
EDIT: Works fine if you leave all 4 plane scope buttons toggled "on" and type "A" explicitly in the field next to it instead of * . Still not sure if this a bug or intentional, don't remember it being like this before, Can someone confirm
