Hello world Posted February 28, 2012 Share Posted February 28, 2012 is there attribute transfer for volumes? could anyone share a simple file to transfer attributes using volumes Quote Link to comment Share on other sites More sharing options...
rafaelfs Posted February 28, 2012 Share Posted February 28, 2012 What exactly are you trying to do with this? There's a volumefromattribute SOP. Once you create a volume from an attribute you can sample the values using a VOPSOP or an AttributefromVolume SOP. Cheers Quote Link to comment Share on other sites More sharing options...
Macha Posted February 28, 2012 Share Posted February 28, 2012 Sounds like you want one volume to get the values from another? You can use volumemix to do that. If you want a bit of "blending" going on then prepend a volumeblur. I'm not sure if you could do this directly from a volumevop. Maybe volumesample or something along those lines. Perhaps, perhaps, I haven' tried. You could also pipe the volume into a timeless dopnet and use the gascalculate to do something fancier. Quote Link to comment Share on other sites More sharing options...
