Newbie doubt
Hello Houdinis
I got a doubt regarding Subnet.
If I have on a new scene 6 boxes of different shapes.
How do I move this 6 containers inside a Geometry container, and this one inside a Subnet container?
Once I do this. Is 1 Merge node enough to merge the 6 boxes?
thanks
trai
Wih an object merge you can select multiple objects ( there is a + button). Or use many objectmerge nodes an then a merge node.
In the object merge node you may have to merge transform into " this object" or use a . to refer to the current object transform.
