Cellular Automata VOP RSL shader
rutra
I've translated Malcolm Kesson's Cellular Automata SL into a Houdini VOP RSL shader (no reason). You can find the original SL on his website
Main difference is that Houdini VOPs don't support arrays so I used multiple connections and 8 texture calls instead of a for loop. Let me know if there is some better way of querying neigbours:)
Original shader cell size and count is dependant on micropolgyons and controlled by shading rate. I've set the shading rate to a very high value and the cell count is controlled by geometric subdivision instead. That meant I couldn't use random function for initialization so I replaced it with cellnoise shadeop.
OTL library contains digital assets:
  • cellular - Object type digital asset
  • bake3d - shadeop for pointcloud baking
  • texture3D - shadeop for pointcloud reading
  • cellnoise - rendermans cellnoise function
  • cellular_automata - cellular.sl VOP node version. Just a direct implementation of the code. Not used for anything.
Cellular is Object Type Digital Asset that contains shaders, geometry and ROPs for 'out of the box' test render.
cellularotl.zip
vops do support arrays! (and have been there in H10 and H11 as far as I remember)
but only if your using an inline vop..or if you write your otl in vex.
H12 has officially launched and it has now support for array inputs etc!
the only thing is to create an array you would have to use an inline vop which lets you write vex code
directly inside vex!
Yes, inline vop would work but I wanted to recreate the shader with minimum amount of code and try to use only existing vops where possible. Just as an exercises to demonstrate that you can translate almost any code to vop network.
