particle angvel
Benyee
Here is an idea:
Get your velocity and acceleration vector. Cross v with acc+v. So, now you have two vectors. Then cross that with v and divide by the square of the magnitude of your previous vector.
If my thinking went well you should have the angular velocity. If not it's nonsense, but close.
edit: Isn't there a default angvel somewhere?
Edited by Macha
  On 3/2/2012 at 6:03 AM, Macha said:
Here is an idea:
You mean like this?angvel_try.hip
Are you talking about angular velocity? afaik it points perpendicular to the plane of rotation for single point (determined by the right-hand rule). But you compute perpednicular part of linear velocity.
btw, i have all my vector markers point in the same direction under ogl 3.2 ,h12 (ogl 2.1 goes fine). Does anybody experience the same?
