Flip Fluids Self-Interaction Problem...
goldleaf
I'm getting to better know Houdini 12 and FLIP fluids, and I thought a good excercise would be to replicate the test that Igor did with Naiad (http://vimeo.com/29045955). To emit my fluids, I have an expression in the Creation Frame parameter:
if($F%5==1,$F,0)
I can't find any 'Mutual Affector' toggles on or in the flipfluidobject or the flipfluidsolver.
Has anyone else had success doing this, and could lend an idea or two?
Thanks!
stacking_sticky_teapots.hipnc
Edited by goldleaf
There's no way to make multiple FLIP objects interact with each other; you should emit a volume of particles into the same FLIP Object at different times. Then for a test like the one you link to (where the different viscous fluids don't interact), just run the simulation multiple times with different viscosity values, each time caching to a different file sequence, then offset the different simulation outputs at render time.
See attached for an example of emitting a volume of particles at intervals.
teapot_stack.hip
Aha! That makes much more sense; I figured it must have been something wrong fundamentally with my approach.
Thanks Johner!
Edit: Oh, btw, how did you get the particles to collide against the bounding box? Mine just want to flow through it...
Edited by goldleaf
Turn on Closed Boundaries on the FLIP Object | Initial Data (similar to Pyro). And make sure the FLIPSolver has Collide With Volume Limits enabled (it's on by default).
