H12_Where is "Create new VOP type"?
thinkinmonkey
Hello all,
I'm using Houdini 12.0.552 and I'm working in SHOP Network.
In H11 I can convert an INLINE op to VOP op selecting "Create new VOP type" from pop-up menu, but I cannot find it in H12.
Maybe SideFX changed workflow: does someone know how to do that?
Thanks in advance.
Isn't it the same thing as "Compile VEX Code to SHOP Type"?
Edit: I'm sorry, I was wrong... Just never use it this way before.
Edit2: Workaround in Houdini Help:
http://www.sidefx.com/docs/houdini12.0/assets/advanced_otl
  Quote
vcc (the VEX compiler) has options for creating OTLs directly from .vfl files. They are described briefly in the vcc usage message.
vcc -m vops.otl shader.vfl
This creates a new VOP operator and puts it in vops.otl. This is exactly what Houdini does now when you choose “Create New VOP Type” from the RMB menu of a SHOP or VOPNET operator.
Edit3: ...But it doesn't work.
Edited by nord3d
Hi, thinkinmonkey, thank you for a tip.
Previously, I used only SOP and SHOP assets and had no experience with VEX Builder type. I mean, didn't know that VEX Builder is for create VOP nodes.
Edited by nord3d
