VEX function to see if a file is readable
Sam Hodge
Hi shady people,
In 3delight, I would use the following function:
http://www.3delight.com/en/uploads/docs/3delight/3delight_35.html#SEC137
color C;
if( textureinfo(texturename, "exists", 0) )
    C = texture(texturename);
else
    C = errorcolor;
But Alas I am now using Mantra and I cant do this.
Which part of the friendly manual did I miss reading?
Sam
I'm grad I could help. Note, that texture() emits "warning" color by default when it can't open the file. It's a bright ping as you may have noticed. It can also be overwritten with HOUDINI_DEFAULT_TEXTURE_COLOR variable:
~$ hconfig -h HOUDINI_DEFAULT_TEXTURE_COLOR
Specifies the default color to use when texture maps cannot be found while rendering. This can be specified as a single string
containing four floating point numbers representing the red, green, blue and alpha components of the default color. For example:
setenv HOUDINI_DEFAULT_TEXTURE_COLOR "0 0 0 0"
to set it to zero black.
cheers,
skk.
