popipu Posted March 8, 2012 Share Posted March 8, 2012 hi all, I meet the problem is how can I use RBD object to be my particles geometry source? when I connect to RBD object it always shows error...... Quote Link to comment Share on other sites More sharing options...
Netvudu Posted March 8, 2012 Share Posted March 8, 2012 Don´t connect the rbd object. Connect what you get from the dopimport SOP to your POP Network, and use that as a source. It sounds like you don´t have a good grasp of the basics. You should study some of the example files to get a good idea on how to work with DOPs. Also be sure to understand how to work in SOPs. Most of the stuff happens there. Quote Link to comment Share on other sites More sharing options...
popipu Posted March 8, 2012 Author Share Posted March 8, 2012 Don´t connect the rbd object. Connect what you get from the dopimport SOP to your POP Network, and use that as a source. It sounds like you don´t have a good grasp of the basics. You should study some of the example files to get a good idea on how to work with DOPs. Also be sure to understand how to work in SOPs. Most of the stuff happens there. thanks for your respones. I am a new user of houdini so everything is still learning...... but i am trying what you say hope is help. thank you so much Quote Link to comment Share on other sites More sharing options...
Benyee Posted March 9, 2012 Share Posted March 9, 2012 (edited) hi all, I meet the problem is how can I use RBD object to be my particles geometry source? when I connect to RBD object it always shows error...... Hi,there are some tutorials:here Edited March 9, 2012 by Benyee Quote Link to comment Share on other sites More sharing options...
