RBD object to be particles geometry source
popipu
Don´t connect the rbd object.
Connect what you get from the dopimport SOP to your POP Network, and use that as a source.
It sounds like you don´t have a good grasp of the basics. You should study some of the example files to get a good idea on how to work with DOPs.
Also be sure to understand how to work in SOPs. Most of the stuff happens there.
thanks for your respones. I am a new user of houdini so everything is still learning......
but i am trying what you say hope is help. thank you so much
  On 3/8/2012 at 7:54 PM, popipu said:
hi all, I meet the problem is how can I use RBD object to be my particles geometry source?
when I connect to RBD object it always shows error......
Hi,there are some tutorials:here
Edited by Benyee
