How to preserve point groups after a ForEach SOP?
I don't know why. I've had this problem before, and it cause me some issues cause I changed the structure of the geometry in the foreach. So I couldn't copy the groups back.
I can't remember, but if you create a point group inside the ForEach that might still work. I've found it often better to use VOP or Point SOP if you are working on just points. I don't find ForEach adds any flexibility that those SOPs can do at the point level.
Thanks, I used foreach to promote attributes per group. Can I do the same using VOPs? I imagine I can't do this with the Point SOP.
You surely can do it in VOP-SOP. There are:
Add Attribute
Import Attribute
Create Point Group
Point In Group (?)
Add Point To Group
Thanks but can I iterate on those groups independently? Because I am promoting from a point to a detail attribute and then from detail to primitives.
So the detail attribute should be stored temporarily per group, not for the whole geometry.
So, perhaps it would be more convenient to first store your groups in some attributes (with VOP SOP) and then use Attrib Promote SOP(s) to promote them to desired type(s)?
Edited by nord3d
