Vectorcasting in vex
gaurav
Greetings folks,
When a vector attribute is added to the points inside vops why does it show up as a 3 floats representaion in details view ?
Same is true when taking a cross product of 2 vectors eg. C = N x V.
Resultant vector C comes out as a 3 floats representation C[0],C[1],C[2] instead of C[x],C[y],C[z]
1. Why so ?
2. Would a vector casting be needed here ? If yes, of what signature and type ?
I would like it to be consistent as the original vector representations which can be accessed by xyz components in local variables.
Thanks,
Edited by vectorblur
as internal computation of VOPs it should be no difference between vectors and 3floats, but if you want to create attribute as vector which adds(xyz) and it's transformed as vector, normal or point, you can simply change Type Modifier on Add Attribute VOP to vector, normal or position
