How do I use .vfl code found at odforce?
edward
Method 1
To install VEX OPerators in Houdini 6.0 & above, go to File -> New Operator Type..., give your VEX OPerator a name, label, select "VEX Type", "Network Type:" is "Surface Shader Operator" [Or another type that matches your shader -Ed].
As for "Save To Library", you can leave it at its default but set "Install Library To" as $HOME/houdini6 or $HOME/houdini6.1.
Next, you'll get a Operator Type Properties dialog, go to the VEX Code tab & copy-paste the VEX code here. Finally, click Apply & you have just installed a new VEX Surface Shader.
Courtesy of Steven Ong
