brucegregory Posted November 17, 2003 Share Posted November 17, 2003 So far, the tutorial examples that I have seen feature particles as points of geometry and particles with sprites attached. It seems to me that fluid simulation might be better realized with the assistance of metaballs, (though that may not be a very processor economic approach). Does anyone know if this is really a practical answer for the modest workstation, or can anyone state the case for using sprites and shaders for moving water simulation? If metaballs attached to particles presents a practical alternative, could someone basically outline the process of "instancing" random sized metaballs to particle locations? Greg Smith Quote Link to comment Share on other sites More sharing options...
doc Posted November 24, 2003 Share Posted November 24, 2003 Hi bruce It depends on what type of effect you're going for. For something like water falling out of a cup, a fountain , or water running off of a surface metaballs would do the trick. >If metaballs attached to particles presents a practical alternative, could >someone basically outline the >process of "instancing" random sized metaballs to particle locations? What you Quote Link to comment Share on other sites More sharing options...
exarhos2003 Posted November 25, 2003 Share Posted November 25, 2003 hello, dont know if youve solved what your looking for, but hope this helps. once you check the stamp inputs in the copy sop, you can create varibles and name them. here i just created a random function rand($PT) to randomize particles. In the transorm sop of your objects, apply this varible in the uniform scale by using the param() function. hope this helps chris Quote Link to comment Share on other sites More sharing options...
brucegregory Posted November 25, 2003 Author Share Posted November 25, 2003 Chris: Thank you very much for this graphic illustration of the technique. A picture is really worth much more than words, (at least to me), so this really hits the nail on the head, so to speak. Yes, it will help a great deal. Now, I just have to go try it. Thanks again, Greg Smith Quote Link to comment Share on other sites More sharing options...
