How to access the iterating group inside Foreach SOP?
I have Font SOPs copied via the Copy SOP. I know I can do this with stamping but after the Copy SOP, I want to use a Foreach SOP to iterate over each group created by the Copy SOP. Inside the foreach, how can I copy each group with a different color?
Using the Color SOP with primitives, detail, points doesn't work. Is there a way to stamp the group name being iterated?
Thanks Hopbin, I see what you mean. I tried copy*, it still worked though in H11. The problem is trying to generate different colors for the whole group but I think it requires storing the copy index too so you can randomize based on this. Color SOP still uses each primitive when you specify a group.
Yeah this works with stamping. I just want to try this because I am wondering if I could access the whole group inside Foreach. Also would be useful if the geometry wasn't created with a Copy SOP, but had groups per object in the geometry.
Ok well if you hadn't created the geo through a copy node (I have in the attached example, but ignore that fact), you can use a connectivitySOP to create an attribute per object, in this case "class" and then a partition sop to split the geo up into groups based on that attribute, in this case "box_*".
From there you can either use the $CLASS variable to colour each node differently, or use the groups in a for each...
Explanation of For Loop Expression:
rand(opdigits(stamps("..", "FORVALUE","")) * 523)
opdigits gets the number on the end of the string, so box_22 will return 22.
stamps(...FORVALUE...) will get you the current stamp name.
Hope this helps
Christian
colorByPartition.hip
