Whatsinaname Posted April 12, 2012 Share Posted April 12, 2012 Hi, In H12, the sourcing system for FLIP fluids was changed, so instead of a common source node that act pretty much like a source node in POPs there is a new and more advanced system (sourcevolume). With this new system I have no clue how to control emission rate, emission frames etc. because all the parameters one usually finds in a Source node's Birth tab are gone. Has anyone an idea how to control Birth Rate with that new system in H12? Thank you very much! Quote Link to comment Share on other sites More sharing options...
3dbeing Posted April 12, 2012 Share Posted April 12, 2012 I ran into the same problem, finally I just used a particleFluid Emitter, which is basically a pops source node. Quote Link to comment Share on other sites More sharing options...
goldleaf Posted April 12, 2012 Share Posted April 12, 2012 Here is an example hip file that does this, and has some notes on what I edited. This is roughly what the shelf tools are doing. Also, thereHere is a thread where igor put up a cool file as well, demonstrating viscosity settings: Viscous Teapots There are other threads as well, and don't overlook scouring the documentation! Good luck! source_flip_fluids_example.hip Quote Link to comment Share on other sites More sharing options...
Whatsinaname Posted April 13, 2012 Author Share Posted April 13, 2012 Tank you very much for the file and information. Quote Link to comment Share on other sites More sharing options...
