Hello world Posted April 13, 2012 Share Posted April 13, 2012 Hi is there any way to start houdini to load file by using the cook mode:manual in windows?? Quote Link to comment Share on other sites More sharing options...
Annon Posted April 13, 2012 Share Posted April 13, 2012 houdini -n Quote Link to comment Share on other sites More sharing options...
old school Posted April 16, 2012 Share Posted April 16, 2012 Yep houdini -n You can copy/paste a shortcut on your desktop (or anywhere) and RMB then just add the -n flag to the houdini command should do it. Here are the other houdini command line options fyi: Usage: houdini.exe [-geometry wxh+x+y][-h][-f][-j nproc][-s editor][filename ...] -geometry: specify window width, height and x and y offsets -h: output this usage message -f: force the use of asset definitions in OTL files on the command line -j: set maximum processors to nproc -s: specify starting desktop by name -n: start up in Never cook mode 1 Quote Link to comment Share on other sites More sharing options...
Hello world Posted April 16, 2012 Author Share Posted April 16, 2012 Yep houdini -n You can copy/paste a shortcut on your desktop (or anywhere) and RMB then just add the -n flag to the houdini command should do it. Here are the other houdini command line options fyi: Usage: houdini.exe [-geometry wxh+x+y][-h][-f][-j nproc][-s editor][filename ...] -geometry: specify window width, height and x and y offsets -h: output this usage message -f: force the use of asset definitions in OTL files on the command line -j: set maximum processors to nproc -s: specify starting desktop by name -n: start up in Never cook mode cool! thanks Quote Link to comment Share on other sites More sharing options...
