Scratch Posted April 19, 2012 Share Posted April 19, 2012 Hey folks, I'm a Maya user and I'm currently learning/exploring Houdini. While experimenting with the mantra surface material (H12) ran into a texture sliding problem. I animated a sphere by diving into its geometry level (SOP) and apending a transform node which is driven by a expression of $FF in the x position attribute to make the sphere move along this axis. When adding this mantra surface material to the sphere, with displacment activated using the build in noise options, I get texture sliding when I render out this image sequence. How can I prevent this from happening? Meaning where are the controls for texture projection or uv options hiding in Houdini? Thx in advance for your help! Looking forward to your answers! Quote Link to comment Share on other sites More sharing options...
sadhu Posted April 19, 2012 Share Posted April 19, 2012 Before applying the transformation use rest sop it will solve the texture sliding problem. At geometry level if you press tab and type uv you will see the tools related to uvs. Quote Link to comment Share on other sites More sharing options...
Scratch Posted April 19, 2012 Author Share Posted April 19, 2012 Wow, thx alot for that quick answer! I'll try that immediately at home and report back! Thx! Quote Link to comment Share on other sites More sharing options...
Scratch Posted April 20, 2012 Author Share Posted April 20, 2012 Works perfectly! Thx alot! Quote Link to comment Share on other sites More sharing options...
