UV-Tiles
I have question for how to arrange UV´s. I did search and found THIS topic but what I want is the reverse. I have many overlapping UV-tiles and want matrix-like alignment of UV´s.
On Sidefx-Forum is similar question. It is not me but I have same question.
Thank you!
Edited by renderfan
dont know what exactly you want to achive, but maybe this wil help you:
it is a python otl, so you can customize it...
Thank you!
uv_perface.otl
Majikal, thank you very much for file. It is not exact what I need but is good starting point for me. I am beginner with Python and can not change Python-Sop to do what I need. I send file to better understand problem. In file is it possible to get UV´s in arrangement of row and column??
Jim, thank you for tip but i did try Uvunwrap-Sop. I think it does not what I need.
Thank you again!!
UV-Tiling.hipnc
Thank you very much, Sadhu!!!
Your file is great I did learn very much. I did try to use same method for my example but was not able to get right result. I get geometry with uv from other programm and to edit uv i want to have uv in matrix-like arrangement.
Thank you again
In your first post the red colored triangles are uvs of separate polygons of your geometry??
In that case
in your geometry, not all the polygons are connected to each other.
Add facet sop after your geometry and select unique points.
Then add uvunwrap sop with appropriate value of spacing parameter.
you will get matrix arrangement of uvs of polygons of the geometry.
