Joker386 Posted May 22, 2012 Share Posted May 22, 2012 Hi I created a coin in the houdini.assign Mantra Surface Material(with Light & Object Reflection) to it. I created a Mantra Node (Pixel Samples : 6 6 and image Size 1280 * 720 ) . but when I render the scene , Houdini Render some frames (for example 1 to 10 ) and after frame 10 Mantra Node Stoped with error. when I take Mantra Node Info by MMB click on it I take below error : Error : Command Exit Code : -1073741819 Why ? Quote Link to comment Share on other sites More sharing options...
