Rainer-D Posted May 25, 2012 Share Posted May 25, 2012 Hello mates, i have a question. What i want to do is basically using a Ramp in VOP SOP and for the total point number in the Ramp i do need to transfer integer values from a CHOP. The idea is to e.g. create a signal with 24Hz sampling rate, the total dot-number of the signal need to be plugged in the Ramp-point number. (The Ramp is divided by the total point number of the chop signal) My question is: Does anyone of you worked already that way and can offer me some tips in terms of transferring attribute-values from chops to VOP SOP for further processing? Many thanks in advance, Rainer Quote Link to comment Share on other sites More sharing options...
3__ Posted May 27, 2012 Share Posted May 27, 2012 Do you wish to edit the ramp or just use it to display CHOP data? Quote Link to comment Share on other sites More sharing options...
Rainer-D Posted August 9, 2012 Author Share Posted August 9, 2012 Do you wish to edit the ramp or just use it to display CHOP data? Hi Mate! Just to display the values and if needed to adjust some by hand afterwards. Quote Link to comment Share on other sites More sharing options...
anim Posted August 9, 2012 Share Posted August 9, 2012 you can use Channel SOP to get data from any chop curve to the points http://www.sidefx.com/docs/houdini12.1/nodes/sop/channel Static method is probably what you want, since it uses point number as index to get value from curve Quote Link to comment Share on other sites More sharing options...
Rainer-D Posted August 10, 2012 Author Share Posted August 10, 2012 you can use Channel SOP to get data from any chop curve to the points http://www.sidefx.com/docs/houdini12.1/nodes/sop/channel Static method is probably what you want, since it uses point number as index to get value from curve Thanks for the Tip, Tomas! Quote Link to comment Share on other sites More sharing options...
