Blackstone Posted June 3, 2012 Share Posted June 3, 2012 Hi, I'm trying to consider Houdini as a generic graph creator and I want to construct a OSL shading network in Houdini, each node is used to store the parameter values, and I could retrieve everything by python script and output the shader as text. For example, I would like to construct a plasic material in OSL, it could be constructed by a diffuse and specular, I wish that in SOHO, plastic - diffuse - specular - add There are three 3 OSL proxy nodes, they would construct a simple graph under the node plastic. How could I create nodes from New Operator Type window ? Thanks ! Quote Link to comment Share on other sites More sharing options...
