How to Create a new VOP Network as Mantra and RSL
Blackstone
Hi all,
I'm trying to integrate the OSL into Houdini.
I think the best way is to define a new VOP Network named OSL Surface SOHO Type for surface shader in OSL, and implement dozens of OSL node in it, and then generate the source code manually.
But once I tried to check the parameters of a RSL Surface SOHO Type[\b], there is a warning said "Not that you cannot create a new VOP Network type.", so that's really impossible even by HDK ? If that's possible, where should I start from ? Thanks !
