Blackstone Posted June 4, 2012 Share Posted June 4, 2012 Hi, I would like to ask how to use VOPNET_Node in HDK, but there is no any info about this class, so is that possible we define a new VopNet by this class as the "RSL Surface SOHO Type" ? I could almost guess out a basic model. class VOPNET_OSL : public VOPNET_Node { public: VOPNET_OSL(OP_Network *parent, const char *name, OP_Operator *entry) : VOPNET_Node(parent, name, entry) { } ~VOPNET_OSL() { } static OP_Node * myConstructor (OP_Network *, const char * name, OP_Operator * entry); static PRM_Template myTemplateList []; }; OP_Node * VOPNET_OSL::myConstructor(OP_Network *net, const char *name, OP_Operator *entry) { return new VOPNET_OSL(net, name, entry); } PRM_Template VOPNET_OSL::myTemplateList[] = { PRM_Template() }; void newVopNetOperator(OP_OperatorTable *table) { OP_Operator *op = new OP_Operator("oslVopNet", "OSL VOP Network", VOPNET_OSL::myConstructor, VOPNET_OSL::myTemplateList, 0, 0); table->addOperator(pOP); } It could appear in VEX->Custom, that's really what I want, but once create it, Houdini throws "5648: Fatal error: Segmentation Fault", and I do not what should I need to do more here, that's really a blackbox to me :'( . Is there any body know this ? Thanks for your kindly help ! Quote Link to comment Share on other sites More sharing options...
edward Posted June 5, 2012 Share Posted June 5, 2012 Have you considered this approach? From the HDK samples: http://www.sidefx.com/docs/hdk12.0/_v_o_p___custom_context_8h_source.html http://www.sidefx.com/docs/hdk12.0/_v_o_p___custom_context_8_c_source.html Quote Link to comment Share on other sites More sharing options...
