HDK basics print out
I have just started to learn HDK, and c++ for that matter, so please excuse my ignorance.
I am attempting to 'frankensteine' the Sop_Star sample.
My really stupid question, is how to just print out a value, so I can start looking at what's going on.
I have tried cout << "hello world", but where does this get printed to.
How can I see print output in houdini ?
The output should happen in the terminal from which you ran Houdini. I know this is how Linux/Mac work, and I would imagine that on Windows, if you are using the command line, it would print the message there as well.
On windows there is a floating console shell window which is hidden and pops up for the first time when you run into some errors (in your code most likely). To change that behavior you need to set some hconfig variables:
HOUDINI_WINDOW_CONSOLE := 0
That's why I prefer starting houdini from cygwin, which makes things more intuitive :)
kuba
