RBD fracture - To increse adhesive strength between pieces.
kidsreturnjj
Hi. I devide object by voronoifracture and use RBD fracture for breaking ground.
I use spheres to hit on ground object to break some part of ground.
But when spheres hit on ground object, whole ground object is broken.
I hope to break just part of ground of object.
So I hope to increse adhesive strength between pieces of ground.
Is there way to do for it?
vo_9_4.hipnc
One of the soln can be creating two seperate groups from the street geo, one you want fracture , convert it in to rbd fracture or glue object and other you dont want to fracture ,convert it in to a static object. See the attached file. I hope it gives you an idea.
Solution_01.hipnc
  • Like 2
I have one question. :)
When you make two group for static and active, how can select each pieces to make a group?
