Performance of the new "Source volume"
Ostap
Yes, it can be quite slow. Once I get the source performance I want I generally cache it before running my sims.
I think it's bound to be slow because it generates volumes from geometry and that, depending on the sample distance, can be quite expensive.
Also, you might want to start with a higher sampling distance, and reduce it in steps until you find a good performance/speed compromise.
Not sure what else can be done about it though...
cheers
Edited by rafaelfs
I don´t think it really is slow. I do think it does a whole lot of things and that comes at a price!! :)
IMHO the importance of proper fluid sourcing can´t never be stressed enough...
Edited by Netvudu
Yes, I didn't mean it in a sense of inefficiency... :)
It's actually a great node!
For one thing, it IS inefficient (and inaccurate) when using with particle fluids, especially if you want to emit fluid from the surface of a geometry. (I ended up creating an own fluid emitter asset). It can also be inaccurate when inheriting attributes from the source geometry (e.g. per-point velocity).
