Log, Exp, Ramps, and Volumes
I always have this problem that volumes piped into a ramp don't respond linearly to your changes. It is very hard to get a good smooth blend between a visual 0 and 1 density.
Now, I noticed that in H12 we have log vex nodes, and even a log parameter type. I think it's just the thing I need!
Does anybody know the proper way to set this up? I tried:
density -> exp -> ramp -> log
and similar variations but no luck.
What is the correct way to do this?
Edit: density -> negate -> exp -> ramp
works better for manipulating low density areas but still fiddly
Edit edit: Uhuh! I found it!! Brilliant!!
ramp -> negate -> power (reverse inputs and use $E) -> complement
Edited by Macha
