kidsreturnjj Posted June 23, 2012 Share Posted June 23, 2012 I saw cubic()expression in position value. what is the fuction of it? Quote Link to comment Share on other sites More sharing options...
ehsan parizi Posted June 23, 2012 Share Posted June 23, 2012 I saw cubic()expression in position value. what is the fuction of it? from exhelp: "This function uses the slopes at either end to solve the differential equation to give a smooth curve between the end points." you can always find help on expressions if you open the HScrpit texport (alt + t) and type : exhelp 'EXPRESSION YOU'RE LOOKING FOR' or exhelp -k 'SOMETHING YOU'RE LOOKING FOR'. for example in this case just type " exhelp cubic" and if you're looking for all the expressions that are related to say "group" you can say "exhelp -k group" Quote Link to comment Share on other sites More sharing options...
kidsreturnjj Posted June 26, 2012 Author Share Posted June 26, 2012 from exhelp: "This function uses the slopes at either end to solve the differential equation to give a smooth curve between the end points." you can always find help on expressions if you open the HScrpit texport (alt + t) and type : exhelp 'EXPRESSION YOU'RE LOOKING FOR' or exhelp -k 'SOMETHING YOU'RE LOOKING FOR'. for example in this case just type " exhelp cubic" and if you're looking for all the expressions that are related to say "group" you can say "exhelp -k group" Thx so much Quote Link to comment Share on other sites More sharing options...
