chrisperry05 Posted June 25, 2012 Share Posted June 25, 2012 Hi, I've decided to try and set up Hqueue to utilise a couple of our machines and i'm running into some trouble and was hoping someone could help me out. I've setup the server on Ubuntu 12 and i've added the server machine as a client and that works fine, however when i try to add another machine through the web interface it adds the client and installs the HQClient folder and user etc. but i get no heartbeat and no info on the machine? I'm trying to connect to a Mac running osx but i get the same result trying to connect to a Laptop running Ubuntu so i don't think it's an OS thing. If i try to restart either machine i get "Failed to restart 'My-Computer': coercing to Unicode: need string or buffer, NoneType found" Just wondering if anyone had run into the same problem? Any help would be great. Cheers Chris Quote Link to comment Share on other sites More sharing options...
eddgarpv Posted October 23, 2016 Share Posted October 23, 2016 I know this is an old post, but just recently had the same problem with a fresh centos 7 install (debian was working perfectly, but had to switch). Anyway, the problem was I had a firewall running in centos. Disabling this solved that 'Unicode: need string' error. I can't restart nodes using the web interface but I can ssh to the nodes. There may be another security option that may be causing this but I still have to find out. Hope this helps somebody in the future. Quote Link to comment Share on other sites More sharing options...
