HDK DSO Loading error
I am getting the following error when I load my hdk sops
Compiler incompatibility detected. gcc compiler versions below 4.3 are not compatible with gcc compiler versions 4.3 or above.
Below is my houdini env
HOUDINI_BUILD_KERNEL=2.6.32-19-generic
HOUDINI_BUILD_VERSION=634
HOUDINI_BUILD_LIBC=glibc 2.11.1
HOUDINI_BUILD_PLATFORM=Debian squeeze/sid
HOUDINI_MINOR_RELEASE=0
HOUDINI_VERSION=12.0.634
HOUDINI_BUILD_COMPILER=4.4.3
HOUDINI_MAJOR_RELEASE=12
HOUDINI_CC=/usr/bin/g++-4.4
HOUDINI_DSO_ERROR=1
Any ideas
Thanks for you help
I am at a facility and when I went on vacation they updated our houdini build.
Now I am trying to figure out why build 12.0.543.9 worked and the new build 12.0.634 has problems.
Thanks for helping.
when I do a g++ -v
I get
gcc version 4.4.5 (Debian 4.4.5-8)
and I did set the HOUDINI_CC.
So frustrating.. I could really use my tools at the moment
  On 6/29/2012 at 1:56 AM, edward said:
Yes, do one of the following:
- Compile using gcc/g++ 4.4, OR
- Install a build of Houdini that matches the gcc version that you want to develop using the HDK.
