DOP data from VOPs
stephenl
Hi, is there any simple way of outputting custom data from a VOP force into DOPS objects. I have a VOP network that calculates whether an object should be active or not and I want to modify the active value based on it. This is a specific example, but later on I bet I will need to do the same with a different VOP net altering a different value.
I suspect I will have to use a sop solver, use a for each to create points at the center of each object, and use a VOP SOP there. It'd be much easier and faster to stay in VOP Forces, though they only have two outputs and it doesn't seem like there is a way to output anything other than force and torque.
