zaren Posted July 7, 2012 Share Posted July 7, 2012 (edited) Hi all! It is possible to render in loop? For example I wrote some post render script which start mantra again. But I got warning - Recursion in parm callback. This is Mantra1/postrender script: i = hou.parm("/obj/control/num").eval() i+= 1 if i < 10: hou.parm("/obj/control/num").set(i) hou.parm("/out/Mantra1/execute").pressButton() /obj/control/num is for to switch geometry. I want to switch geometry and render it. In this case I have 10 : /obj/geometry0 ... /obj/geometry10 If I press button Render - Mantra1 start once. Script executed successes but last string. It seems merely ignored. After render first frame script is started but without continue. Thanx, Sergiy Edited July 7, 2012 by zaren 1 Quote Link to comment Share on other sites More sharing options...
mawi Posted July 7, 2012 Share Posted July 7, 2012 (edited) Hi all! It is possible to render in loop? For example I wrote some post render script which start mantra again. But I got warning - Recursion in parm callback. This is Mantra1/postrender script: i = hou.parm("/obj/control/num").eval() i+= 1 if i < 10: hou.parm("/obj/control/num").set(i) hou.parm("/out/Mantra1/execute").pressButton() /obj/control/num is for to switch geometry. I want to switch geometry and render it. In this case I have 10 : /obj/geometry0 ... /obj/geometry10 If I press button Render - Mantra1 start once. Script executed successes but last string. It seems merely ignored. After render first frame script is started but without continue. Thanx, Take a look at the wedge ROP, it renders a ROP node n-times and can update parameters for each itteration. There is a old video about it on the sidefx.com tutorials pages. Edited July 7, 2012 by mawi Quote Link to comment Share on other sites More sharing options...
strages Posted October 17, 2012 Share Posted October 17, 2012 really nice to find this thing so easily, making use of this right now Quote Link to comment Share on other sites More sharing options...
Shalinar Posted January 13, 2017 Share Posted January 13, 2017 (edited) Bump. Wedge ROP is not good enough for what I need. I'm building out a whole custom ROP loop node set, like the For Loop in SOPs. But every way I try to get a parm to re-execute a button's callback script, I get the "Recursion in parm callback" error. Which is annoying, because I know there's a recursion in the parm callback. That's exactly what I want lol. Is there any way around this? EDIT: I suppose one way would be the Shell ROP, but I'd rather do it all through Python than having extra nodes laying around in my ROP loop. Thanks, ~Chris Edited January 13, 2017 by Shalinar Quote Link to comment Share on other sites More sharing options...
