dark_cry Posted July 14, 2012 Share Posted July 14, 2012 hi all, i built simple shader to get nice AO without lighting and getting wierd result. I'm new in Houdini and this is my first try to render the scene. Please SOS... Quote Link to comment Share on other sites More sharing options...
dark_cry Posted July 14, 2012 Author Share Posted July 14, 2012 this is the scene file musey.rarFetching info... Quote Link to comment Share on other sites More sharing options...
jkunz07 Posted July 14, 2012 Share Posted July 14, 2012 On 7/14/2012 at 8:41 PM, dark_cry said: this is the scene file The background color of the ambient occlusion should be 2 if you want to get pure white and are planning to multiply this onto another pass. The black areas are happening because those normals are reversed Quote Link to comment Share on other sites More sharing options...
dark_cry Posted July 14, 2012 Author Share Posted July 14, 2012 On 7/14/2012 at 10:53 PM, jkunz07 said: The background color of the ambient occlusion should be 2 if you want to get pure white and are planning to multiply this onto another pass. The black areas are happening because those normals are reversed But i tried to reverse the normals but no effect:( Quote Link to comment Share on other sites More sharing options...
jkunz07 Posted July 14, 2012 Share Posted July 14, 2012 On 7/14/2012 at 10:59 PM, dark_cry said: But i tried to reverse the normals but no effect:( I'm guessing that reversed all the normals - you would have to manually select the faces/points that have reversed normals and then reverse only those to fix the problem. From my experience that's part of the problem of working with download geo, there's always stuff like that you have to fix. You could pull the max ray distance all the way down to something like 0.1 but then you don't have a very effective AO pass. Quote Link to comment Share on other sites More sharing options...
anim Posted July 14, 2012 Share Posted July 14, 2012 usually you can use Front Face VOP to N input to force normal to point towards camera for back facing primitives but because Occlusion VOP is doing this by default when nothing is plugged to N, just leave the N input unconnected and you should be ok Quote Link to comment Share on other sites More sharing options...
