Access custom script in HDA
esan
I am trying to embed python modules in OTLs so that they get baked in to the OTL and is easier to distribute. However, I am unable to figure out how to execute that embedded python code form buttons or menus in the OTL. I can get the script in the PythonModule section of the OTL to work but if I import a 'Custom Script' through the 'Operator Type Properties' window then I am unable to figure out the right python syntax to access it.
If the python function is in the PythonModule then I can do the following in the menu button to execute it:
node.hdaModule().somePythonFunction(node)
What is the correct way of accessing the same function if it is in a 'Custom Script' section?
If you have code in additional sections you need to convert those sections to modules in your PythonModule using the toolutils module.
For example, if you had a function foo() in an extra scripts section called "AdditionalCode", you would do this in your main PythonModule:
import toolutils
mymodule = toolutils.createModuleFromSection("mymodule", kwargs['type'], "AdditionalCode")
You can then do this:
node.hm().mymodule.foo()
Edited by graham
import toolutils
Brilliant!
Thanks - that works perfectly.
  • 7 months later...
