Cannot connect to license server...
Hello All,
I've just finished an amazing course at Escape Studios and after a brief break from the computer I'm returning to continue work on my project. Only problem I have is a licensing error...
On loading Houdini the License Administrator loads with an error -
"Cannot connect to license server on unknown-00-23-xx-xx-xx.config"
In the License Administrator, Server Information tab I've got three red X's - The license server is not running, The license server may not serve licenses and The license server does not allow this machine to read licenses
I have purchased a Houdini Apprentice HD license and it has worked previously. I have no idea what has changed or happened to end up with an unknown config and three red X's.
Has anyone had a similar issue and fixed it or know what might have happened?
Thank you for your help in advance,
Regards,
Moth
Drop SideFX technical support an email with a screen grab of the diagnostics page. They'll sort you out!
Thanks for the quick responce woodenduck. I've sent the License Administrator's diagnostic information page to SideFX.
