position RBD Pin Constraint on specific point of geo
yoan
you can use SBD pin constraint for it, just specify both objects and points on both of them, you can connect more points within 1 instance
or maybe SBD spring constraint will be more what you want since it allows for some tolerance so the points don't snap immediately
