cowboy71 Posted July 27, 2012 Share Posted July 27, 2012 Hey guys, I recently have been going through the CMI hip tricks vol 4 erosion tutorial. I get to where he starts running into problems with the points not spreading. He comes back and fixes the errors, and I also fix the same spots and still nothing happens. Just curious if anyone else has run into this issue, and if so how did you go about fixing it. Quote Link to comment Share on other sites More sharing options...
varomix Posted July 27, 2012 Share Posted July 27, 2012 Hey guys, I recently have been going through the CMI hip tricks vol 4 erosion tutorial. I get to where he starts running into problems with the points not spreading. He comes back and fixes the errors, and I also fix the same spots and still nothing happens. Just curious if anyone else has run into this issue, and if so how did you go about fixing it. Hi David I had 2 things wrong in that scene the while VOP needed to be set as True==0 and in the vopsop1 I needed to change the point cloud texture to use the second input op:`opinputpath(".", 1)` if you need more help you can mail me directly at varomix@cmivfx.com thank you Quote Link to comment Share on other sites More sharing options...
cowboy71 Posted July 27, 2012 Author Share Posted July 27, 2012 Great, I just sent over a simple scene file. Thank you. Quote Link to comment Share on other sites More sharing options...
varomix Posted July 27, 2012 Share Posted July 27, 2012 inside the if-then block your're passing the point normals, you need to change that to point NUMBERS see your email for details cheers!! Quote Link to comment Share on other sites More sharing options...
