How To Bake RBD to keys? send to Maya
cool1986vfx
Hey everyone, Who know how to bake simulation RBD to keys in Houdini? like shapes with key frames without simulations on finish?
And also possibly send that animation through fbx to Maya? or any else ways can do that?
Thanks
Best Regards
Evgeny.
Mail me cool1986vfx@gmail.com
skype: cool1986vfx
Edited by cool1986vfx
Done it in the past by exporting out a chan file for each RBD piece, and then in Maya I wrote a script that would read in a obj for each RBD piece and read the chan file and apply the animation back to the geometry.
A little cumbersome, but easy enough if you know Mel/Python.
to Scratch I try to import in Maya Bgeo, I dont know, but this is not work, Maya every time break down, and files is not very weight, can u write in deep steps how u do that please.
to Ratman, I see how do that sinchronize with maya very good deal, I am also try up both server between Maya and houdini , this is works, but I have not very many expirience with python , I do not know wich comand need write for sending in Maya(
Thanks Again.
Best Regards
Evgeny.
No worries, here is a more indepth explaination how it works:
build your geometry inside houdini. At the end of the sop-network, attach a ROP Output Driver. Where it says output file, configer it something like this
$HIP/test_§F4.obj
if you change (manually typing!) the file-extention, houdini will recognize and export obj instead of bgeo. There is no menue for this, just type the file-extention you want to have, and it will work (at least for me it did, I aswell do not know everything in every detail). the §F4 part is the frame padding so that you end up with a sequence, and the 4 sais make the padding 4 digis, starting with 0000. If you need more or less digits, just type the number you like. E.g when you have only 100 frames to export, you also can get away with §F3, starting with 000, ending with 100. Here you can find some more information on filename syntax: http://odforce.net/wiki/index.php/FilenameSyntax
For more information on supported file formats visit this link:
http://odforce.net/wiki/index.php/FileFormats
Further reading: OBJ Files Across Maya and Houdini
http://hurdfx.blogspot.co.at/2011/06/houdini-notebook-4-obj-files-across.html
hope that helps a bit more :)
hey Thanks Scratch, I needed to try that, also Yesterday I try export dynamics with FBX , and this is works, I don`t know why but all animation is export and reads from fpc folder cash inside Maya.
look at the pictures in attachment
Thanks Again.
Best Regards
Evgeny.
Hi
if you happen to be on maya 2013 you can use PIPELINE CACHE
From houdini in Outputs drop in a Alembic node
Then in maya 2013 use the Import Alembic
It will be one big file
I would first bake the RBD into houdini´s geo formate first
mangi
Edited by mangi
Ratman´s method is before almebic came out, yes I did also use these methods.
try Alembic you will be impressed. You do not have to deal with all of those extra files (sequences)
It´s all in one. easy to manage , may get big files sizes
mangi
It´s in MAYA 2012 SAP version
Subscription Advanced package
No need for plugins in that version. No I don´t know about any plugging for early version , but I guess if you look you may find something If your on maya 2012 go for the SAP version
mangi
hey, Thank You Mangi awesome!!!
Did u know how to plugin in pervius version Maya alembic? because some plugins what I need in pervius versions don`t work(
mangi
greeting mangi its very help! thank You Guys!!!
I right now working on dynamics with chains can You are help with this issue?
Thanks!
Evgeny
