Optimizing/Render RBD point objects
Hi, i am having some problems managing data/sims/cache to render my RBD instance objects.
Would like to ask what is the usual workflow and if im doing anything wrong
My current scene workflow
- defining a source to emit particles using a popnet
- then using rbd point object to bring in the particles (cached bgeo)
- also in geo path i am overriding point value with a a range of SOP geo using `$OBJID%5+1`
- i have animated obj interacting with rbd point object
- cached this out as .sim with compression
Here is where the issues start to arise,
- reading the .sim files is taking a hit on my system and getting slow in playing back the cache to see result
- avg cached file size is about 70mb using compression
Questions,
- what is recommended to render these rbd point objects?
- where can i import these objects and assign my shader?
- if my shader has displacement does it treat each geo as unique?
- if i need the rbdpoint objects to interact with pyro how do i manage this data since reading them is already taking a long time?
Thanks in advance for any advice
