If statement Problem
Xims
Can someone help?
I have this code:
if(hasprimattrib("../roadtype", "Road_0"),==1,0,
if(hasprimattrib("../roadtype", "Road_1"),==1,2,
if(hasprimattrib("../roadtype", "Road_2"),==1,2,
if(hasprimattrib("../roadtype", "Road_3"),==1,2,
if(hasprimattrib("../roadtype", "Road_4"),==1,2,
if(hasprimattrib("../roadtype", "Road_5"),==1,2,
if(hasprimattrib("../roadtype", "Road_6"),==1,2,
if(hasprimattrib("../roadtype", "Road_0_Road_1"),==1,1,
if(hasprimattrib("../roadtype", "Road_0_Road_2"),==1,1,
if(hasprimattrib("../roadtype", "Road_0_Road_3"),==1,1,
if(hasprimattrib("../roadtype", "Road_0_Road_4"),==1,1,
if(hasprimattrib("../roadtype", "Road_0_Road_5"),==1,1,
if(hasprimattrib("../roadtype", "Road_0_Road_6"),==1,1,
if(hasprimattrib("../roadtype", "Road_1_Road_2"),==1,2,
if(hasprimattrib("../roadtype", "Road_1_Road_3"),==1,2,
if(hasprimattrib("../roadtype", "Road_1_Road_4"),==1,2,
if(hasprimattrib("../roadtype", "Road_1_Road_5"),==1,2,
if(hasprimattrib("../roadtype", "Road_1_Road_6"),==1,2,
if(hasprimattrib("../roadtype", "Road_2_Road_3"),==1,2,
if(hasprimattrib("../roadtype", "Road_2_Road_4"),==1,2,
if(hasprimattrib("../roadtype", "Road_2_Road_5"),==1,2,
if(hasprimattrib("../roadtype", "Road_2_Road_6"),==1,2,
if(hasprimattrib("../roadtype", "Road_3_Road_4"),==1,2,
if(hasprimattrib("../roadtype", "Road_3_Road_5"),==1,2,
if(hasprimattrib("../roadtype", "Road_3_Road_6"),==1,2,
if(hasprimattrib("../roadtype", "Road_4_Road_5"),==1,2,
if(hasprimattrib("../roadtype", "Road_4_Road_6"),==1,2,
if(hasprimattrib("../roadtype", "Road_5_Road_6"),==1,2,0))))))))))))))))))))))))))))
The problem is that it takes houdini around 20 minutes to accept it.
It does work after that, but am i doing something wrong?
Or is there another way to whrite this that it works fast?
does it really work?
what is returned from
if(hasprimattrib("../roadtype", "Road_0"),==1, 0, if... ) ?
since as correct syntax I would assume
if(hasprimattrib("../roadtype", "Road_0")==1, 0, if... )
or simply
if(hasprimattrib("../roadtype", "Road_0"), 0, if... )
or simply
yes it does seem work that way.
I tried it the way you showed by simply using
But it still has the same problem. :(
  On 8/8/2012 at 3:58 PM, hopbin9 said:
I'd change that to a Python expression and use for loops to check for the attributes.
How should I write that?
My knowledge of python is almost zero.
Edited by Xims
Guest mantragora
First, I would start by rewriting it to this form that you can find in my post there. So you could at least understand what is happening there.
After that I would rewrite it in inlineCPP or HDK.
Thanks for the link mantragorma
I think i'm doing it all wrong but is used it simply like this
    # Come back, come back to me
    comeback = 0;
    # I'll be waiting,
    ptype = hasprimattrib("../roadtype", "Road_0");
    if (ptype == 0)
        comeback = 0;
    else if (ptype == 1) comeback = 1;
    else comeback = 2;
    # patiently
    return  comeback;
I can understand the way its set up but am I allowed a houdini expression in python like this?
I'm getting a syntex error on the:
comeback = 0; part.
Guest mantragora
comeback = 0; part.
1) This is Hscript not Python so don't switch operator to Python mode.
2) If I tried your expression my Houdini hangs for a while, don't know if it works, still waiting for it to complete. Anyway, I rewrited this to more managable form (I'm a little sleepy so maybe I made some mistakes) and it works without problems and very fast.
    comeback = 0;
    if(hasprimattrib("../OUT", "Road_0")) comeback = 0;
    else if(hasprimattrib("../OUT", "Road_1")) comeback = 2;
    else if(hasprimattrib("../OUT", "Road_2")) comeback = 2;
    else if(hasprimattrib("../OUT", "Road_3")) comeback = 2;
    else if(hasprimattrib("../OUT", "Road_4")) comeback = 2;
    else if(hasprimattrib("../OUT", "Road_5")) comeback = 2;
    else if(hasprimattrib("../OUT", "Road_6")) comeback = 2;
    else if(hasprimattrib("../OUT", "Road_0_Road_1")) comeback = 1;
    else if(hasprimattrib("../OUT", "Road_0_Road_2")) comeback = 1;
    else if(hasprimattrib("../OUT", "Road_0_Road_3")) comeback = 1;
    else if(hasprimattrib("../OUT", "Road_0_Road_4")) comeback = 1;
    else if(hasprimattrib("../OUT", "Road_0_Road_5")) comeback = 1;
    else if(hasprimattrib("../OUT", "Road_0_Road_6")) comeback = 1;
    else if(hasprimattrib("../OUT", "Road_1_Road_2")) comeback = 2;
    else if(hasprimattrib("../OUT", "Road_1_Road_3")) comeback = 2;
    else if(hasprimattrib("../OUT", "Road_1_Road_4")) comeback = 2;
    else if(hasprimattrib("../OUT", "Road_1_Road_5")) comeback = 2;
    else if(hasprimattrib("../OUT", "Road_1_Road_6")) comeback = 2;
    else if(hasprimattrib("../OUT", "Road_2_Road_3")) comeback = 2;
    else if(hasprimattrib("../OUT", "Road_2_Road_4")) comeback = 2;
    else if(hasprimattrib("../OUT", "Road_2_Road_5")) comeback = 2;
    else if(hasprimattrib("../OUT", "Road_2_Road_6")) comeback = 2;
    else if(hasprimattrib("../OUT", "Road_3_Road_4")) comeback = 2;
    else if(hasprimattrib("../OUT", "Road_3_Road_5")) comeback = 2;
    else if(hasprimattrib("../OUT", "Road_3_Road_6")) comeback = 2;
    else if(hasprimattrib("../OUT", "Road_4_Road_5")) comeback = 2;
    else if(hasprimattrib("../OUT", "Road_4_Road_6")) comeback = 2;
    else if(hasprimattrib("../OUT", "Road_5_Road_6")) comeback = 2;
    else comeback = 0;
    return comeback;
/OUT
here is python version
geo = hou.pwd().node("../road_type").geometry()
attrib_pairs = { 'Road_0':0, 'Road_1':2, 'Road_2':2 }
result = -1
prim_attribs = [attrib.name() for attrib in geo.primAttribs()]
for attrib, value in attrib_pairs.iteritems():
    if attrib in prim_attribs:
        result = value
        break
return result
here it is with comments:
# get geometry from some node
# define your attributename-resulting value pair dictionary here (I didn't fill it with all your values, so feel free to extend it)
# value returned if no above defined attribute name found on geometry
result = -1
# get names of all primitive attributes on the geometry as list
# loop over all prim attribs on geometry and return first match with above defined dictionary
        result = value
        break
return result
Guest mantragora
Lol, is there speed difference between commented and not-commented version ? :)
I guess not, just to distinguish what's the actual necessary code for Xims since he is Python beginner
version with comments may be a little messy to look at, but good for trying to understand the steps
    comeback = 0;
    else comeback = 0;
    return comeback;
/OUT
thanks allot this one works great.
I didnt think you could use an else if funcion in houdini exspression because I didnt find it in de documentation
I havent been using houdini for long so i'm still learning allot.
Still I wonder why mine works so slow :s
result = -1
        result = value
        break
return result
result = -1
        result = value
        break
return result
Thanks anim
I'll try both the houdini expression and the python.
I really need to start learning python. :P
Thanks for all the feedback people.
