fur and normals
Hello world
I have a motion for the normals.Can i apply the motion to the fur.Any simple example files? I havent played with fur before
Go into the fur network created, there should be a skin geometry network. If you add an attribute sop somewhere in here you could specify "N" in the from field and "furdirection" in the to field.
That should be all that is needed.
  • 1 month later...
