doc Posted August 23, 2012 Share Posted August 23, 2012 I know that you can set a width attribute on a curve to have it render and by default the surface of the curve will always face camera, but I was wondering if there's an attribute you can add that can override witch way the "surface" of the curve pointing? I tried adding a normal and an upvector, but that didn't seem to work. any ideas? thanks Quote Link to comment Share on other sites More sharing options...
petz Posted August 23, 2012 Share Posted August 23, 2012 adding an attribute called "orient" should do it. hth. petz Quote Link to comment Share on other sites More sharing options...
doc Posted August 24, 2012 Author Share Posted August 24, 2012 of course Quote Link to comment Share on other sites More sharing options...
old school Posted August 28, 2012 Share Posted August 28, 2012 For the uninitiated that would be an orient attribute of type vector where the orientation vector determines the orientation of the ribbon rendered in Mantra. 1 Quote Link to comment Share on other sites More sharing options...
