Is there a way to hide a built-in SOP?
If you have your own SOP that replaces an existing one like the Line SOP for instance, is there a way to hide the default one so you don't see both Line SOPs in the tab menu? I tried to modify the name and category field but it's already empty. I assume there will be some command to do this at Houdini startup?
Thanks man, that should do it :)
I will put it in my 123 file. Although that made me remember I use 123.py, so is there a Python version, or should I call the hscriptexpression Python function?
Edited by magneto
