Why compare doesn't work ?
lzoper
Hi Izoper.
Attribs like LVLH and LVLSF, dont transfer them using attrib transfer pop as it is distance based. Instead let the particles inherit them by connecting output of exp_lvlh null to ToEmmit group sop, by default particles will inherit these attribs. Delete attrib transfer pop.
Second problem is in level helper null, min level is set to 5 . Set this value to zero and you will get desired result. This para is not necessary in the current scenario.
formation_01.hipnc
