Error when starting houdini
Minterta
Hello,
This is my first start at houdini and I getting this error(in the houdini console): "Unable to link glDrawElementsBaseVertex" when I start houdini FX. I google it but there where none results.
Then after adding a Box to the scen I get this error(in the houdini console):
976: Fatal error: Segmentation Fault
Saving application data to C:/Users/FRANKD~1/AppData/Local/Temp/frankdenuijl.976.hip
I have attach the .hip file to the attachment.
Does someone knows what it means/how to fix this?
Thanks,
What graphics card and driver do you have?
The glDrawElementsBaseVertex() message means that the driver is advertising support that includes this feature, but is not providing an API entry point for it. Tsk, tsk. It should be in OpenGL 3.2 or in the GL_ARB_draw_elements_base_vertex extension if the OpenGL version < 3.2.
